Brembo Conversion - Brake Lines
Hey guys
For those who has converted to Brembo front and rear from GTR, what aftermarket brake lines do you buy for the rear? I've heard the stock s15 lines will work in the front but not sure on the rear
Custom braided lines are hard to get over this side of the world (and prohibitively expensive) so will need to buy off the shelf ones... hence the question
Do I buy the s15 brake lines or GTR brake lines?
Thanks
try dan at db-power with your requirements mate, a full set of lines is normally 60 gbp plus whatever shipping is to aus ;)
13 June 2010
Pisa, Italy
www.flickr.com
Brembo's use the stock banjo-type lines. The stock GTR lines should fit right onto your car also.
Ah ok - if you have done the conversion then it's definate enough!
Thanks
drifter
4 April 2011
Norfolk
I used hoses from Apex Performance :) Front and rear to suit R33 GTR Brembos, worked fine :)
13 June 2010
Pisa, Italy
www.flickr.com
I have R33 twinpots on the rear also, the stock lines fit if your remove the little nipple inside the caliper. I was saying though that if the Brembos came with lines that the stock Brembo lines will fit up to the stock S15 hardlines.
5 October 2009
no they wont, the twin pots run different sizes than single pot s15. The R33 have banjos aswell, unless GTR R33 are different as I have nissan twin pots from r33 gts on rear not brembo.
dont want to start an argument but I went through all this when coverting my rears to r33 and have physically tried them
That's the reason why i started this thread! but i will update you guys as i'm going through converting to brembos all round
Pretty sure front brembo uses the same lines as stock but rear is the tricky bit but i will find out
5 October 2009
all nissan rear pipes fit to your hardlines so just get brake pipes to fit the caliper and your sorted.
Go with the hose that the caliper is designed for to be safe!
Fitting the handbrake mechanism is pretty tough, how are you tackling removing the hubs?
13 June 2010
Pisa, Italy
www.flickr.com
Hold on, are you saying the S15 lines won't fit up to R33 calipers or the R33 lines won't fit up to the S15 hardlines?
I have R33 GTS25T 2 pot calipers on my car using the stock S15 banjo lines(I upgraded to stainless but still the stock-type with banjo fittings). But, I had to remove the little fitting that is inside of the R33 caliper so that the bolt would seat all the way in.
5 October 2009
fair play, I didnt know that... I was buying new braided lines anyway and got gtst ones
13 June 2010
Pisa, Italy
www.flickr.com
Ok, glad we got that sorted. That is for the non-brembo R32/R32 GTR/R33/Z32 calipers. As far as what lines to use for the rear Brembo's I can not help. I have Evo IX Brembos on the front and they also use stock Banjo fittings.
According to this the Skyline and 350z Brembos use the non-banjo fitting but as I said my Evo Brembo's use the banjo bolts.
http://splparts.com/store/product-info.php?pid64.html
These are the lines I'm using by the way, great quality. I don't know if it would be cost effective for you however being in the UK.
tefu
Hi guys on this topic, would the EVO rear brembos fit S15? or hard hard is it to set them up?
I assume you need the handbrake lines from R33 right??
26 May 2009
Frozen Canada eh!
From what I understand, you'll want to try and hunt down a set of STI rears. I plan to do the conversion and both Evo and STI fronts will work with adapter brackets, conversion lines, and a little bit of work. For the rears, STI work the best. Judging by the mega thread over on Zilvia, you'd be hard pressed to make it work.
