Someone please stop my confussion
12 August 2013
Horsham, West Sussex
@liamb91
Hi all
Just about getting round to fit my FMIC on the weekend :thumbs: Only problem i have is whats the best to run for the engine.
Basically i want to aim for a stage 1a/2 on the S15. want to run a safe 1bar of boost and maz 1.1bar
Whats best to do on the recirc side of things?
Run the stock recirc, can this be plumbed in with the fmic?
Im sure ive read somewhere it will start leaking over 1bar.
Dont want to run a dumpvalve as that just more problems, so can i run buy an uprated recirc, where from? which ones best?
Im a huge worrier that im gonna wreck things :cry:
4 August 2011
The standard recirc can be modified quite simply to stop it leaking. You should also be able to plumb it in to the fmic without too much hassle.
MRI believe h-dev sold an uprated one but can't comment on how good it is.
I run without a bov at all as I like the chatter :D
12 August 2013
@liamb91
Doest that stall the turbo, wearing everything faster ect?
6 July 2013
Brisbane
There is lots of different options. But because i run this, i will recommend it.
A mushimoto tube and fin intercooler. I run a 600 x 300 x 76. With 3inch tank ends.
As for piping, sometimes its best to get custom piping done. If you dont have that available, then check out the regular ebay shops for piping kits.
It all depends on the BOV you are running and the silicone joining hoses you have.
There are many variables but its best to have good linkages and a good efficient core.
Hope it all works out for you.
What ever you run wether stock BOV or aftermarket, just make sure you re circulate the vented return air, as it will muck with your AFR's as it is a MAF setup and measures the returned air.
I run a forge uprated recirc valve does the job very well , can also buy a set of springs to adjust it for different boost levels , sounds nice too ;)
12 August 2013
@liamb91
Ive got an Autobahn88 FMIC Kit, that will do the job i want for decent money. I just want the car to run perfect without destroy the Air/fuel ect.
12 August 2013
@liamb91
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0006&product=FMGTIR017
The link for the spring tuning kit is on the page also.
May be able to get It cheaper elsewhere
Sweet dude thanks, easy to fit? Come with the hose and clamps?
Am i right in thinking the stock boost is 0.7 bar around 12-13 psi?! (Green spring)
So i'll need to also buy a yellow spring? or can i just run it with the yellow one on stock boost?
Or to be more jdm buy an hks ssqv, with the recirc adaptor. :)
basically I run an hks ssqv BOV recirculated back into my intake, using one aftermarket pipe and the original piping. You still get awesome turbo chatter but such better throttle response.
So in short, buy a recirculating dump valve, fit the FMIC, fit the BOV to the intercooler piping then connect some pipes so it goes back into your intake pipe work. And you will be ok!
But make sure you get it remapped if running over .9bar, and get a walbro fuel pump fitted too.
12 August 2013
@liamb91
Ive heard of these HKS ssqv bov kit but where can i buy one? what size pipe do i need though (aftermarket pipe you talk of)
Ill be running it on stock boost for a bit, while i collect, Elbow, Mani, Downpipe, Walbro and a Map, should i buy some bigger injectors too?
Max
31 October 2010
Cornwall
If you see a new HKS one dead cheap on ebay for instance its a fake! Make sure to buy from a reputable company.
I use a recirced HKS too.
480 injectors will be pretty much at 100% duty if you try to map for 1.2bar 1.0bar on 480cc is a safe bet, if you like your injectors you really need to be at least 550 with 1+ kind of boost just to have a reasonable duty cycle, SAMs right BELOW 1.2 with 480's. Nismo 740's at 1.2-1.3 will only see about 55-60%, 550's if i remember rightly is around 80-85%
Injectors not needed if you you want to stay below 1.2 bar.
The tubing is 25mm internal diameter. Just some reinforced silicone pipe should work.
So an hks ssqv is not cheap, but its the best. Can be bought here http://www.frsport.com/S14-SR20DET-Super-Sequential-Blow-Off-Valve-Kit-SSQV3_p_15486.html
Its prob as much as your whole fmic.
12 August 2013
@liamb91
12 August 2013
@liamb91
My PC wont let me view the page :( so i'll buy the SSQV and some of the below then i'll have a lovely uprated recirc, which can run on stock boost and 1bar when i get it all mapped, boost controller ect :)
http://www.ebay.co.uk/itm/Silicone-...ing_MJ&var=&hash=item2c71a2d7c4#ht_2809wt_954
1 January 2012
If you ever intend to upgrade your ECU, you could just go the path of MAP sensor rather than MAF. That's what I'm intending on doing. That would eliminate the need to recirculate
