- 14 April 2007
- Shropshire, UK
- www.lupix.co.uk
Ok - did my box oil change for first time since I had Silvia so thought I'd take a pic to show where everything is as there's been confusion recently about where the drain and fill plugs are lol...
So as you can see the fill and drain are both on the passenger N/S of the gearbox. Can't miss them as they're 24mm sized large bolts. The drain is near bottom and the fill is further up.
To fill, if you have syringe then great but I don't so I used garden hose which is fed through the gearstick area at the top (remove all associated centre console trim and there's easy access). I shoved in just under 2 litres and it never overflowed so I thought I'd leave it at that. All done
James
James
