ok, good news and bad news.  Good news is that the pads are in, all done, all good :thumbs:   You know, it wasn't nearly as bad as I expected.  I took my time, so no time records were set, but do it once do it right eh?  I undid the caliper bleed valves and hooked them up to a "one man bleed valve kit", this way when you wind the pistons, all the fluid simply drains out and winding the piston is a breeze - even long nose pliers can do this easily.  The big resistance comes when you leave the valve shut as you have to force fluid through the whole system with every turn - hence the pain.  So I gave the brakes a quick bleed after the install and now its all good - phew.  The only pain is cracking the 17mm bolts, those puppies are on tight - I nearly popped a eyeball undoing those!
ok now the bad news - I got a speeding ticket! me!  99.9% of the time I drive like I'm driving miss Daisy, and on the .1% when I speed, I get busted by the 50 - go figure.  I've never had a ticket before.  If I sped all the time and got busted, then fair enough.  But to get busted on the exception to the rule...
   Now I can't tell people I've never had a speeding ticket - I was so proud of that (and got plenty of milage out of it too
Ok - here's the breakdown.  It's 11.30pm, I'm on an industrial back road, there are no cars in sight - except one set of headlights far behind me.  So I think, "better make sure my turbo still works"
 , I give it a blip - only for a second, and then - there's a Christmas tree behind me.
   The one set of headlights behind me was an unmarked cop car.  I am then given the boy racer serve with a side order of "and you wonder why we pick on you guys"  :rant: .  I love prejudice - one false move and all of a sudden I'm just another punk ripping up handbrakes in the diesel...
chalk one up for impeccable timing
