Battery relocation
29 July 2013
Derby
How easy is it to do, what do you need (any recommended battery cages?) & if you got a garage to do it, what sort of price would it cost + any recommended places that do it?
Thanks.
squeral
24 September 2012
Cornwall
You could try calling Dan at tdc garage 01525 220054, he use to sell kits when he had a company called DB-power
^ this . He helped me source all the parts I needed for my relocation , easy to do when you have the right bits : think it came to about £100 in the end
14 September 2007
Essex
@4ndy_hunt
I got my cable and connectors from the web site drifter put up. I then went and got the terminal (jump start point) in the engine bay from a BMW in a breakers. really need to go back and neatern mine up as it was a bit rushed.
24 January 2013
Kent
I'm in the process of doing this to mine. Well I've bought all the bits and just waiting to fit it. somewhere on the forum is a thread i think created by peg^ that lists all what you need. I bought all my stuff off ebay as tbh its only cables and connections you need. I'm using a battery from an E46 328 from halfords for about £60. it might be overkill but its going in the boot and my last battery was about the size of a nokia 3310 battery! Other options for this that people have done is get the wiring from 3 series BMW's as they have battery in the boot and can work out cheaper if you can find one.
In terms of install its quite simple- run power cable from positive in the engine bay. through the interior to the boot. Install as breaker before you get to the battery then earth the battery to metal in the boot. get a tray made up/buy one and mount it wherever you want it.
Cess
Instagram Staff
10 February 2013
Northern Ireland
Basically chop the terminals off and re-route using extra cable, into the boot?
