Boost Pressure Leak?
Are you driving with det headphones on? That's the only way to be 100% sure you've not got det... As stated, mine had det not much over 0.8 bar when Jez did my first custom mapping.
24 February 2006
Plymouth
No that would be dangerous... was setup at Jefferys... they tried loads of different boost settings as they are getting more and more SR20's there so wanted to play and do some tests
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
I think for now Im just going to get hold of a stock actuator.
Not knowing a lot about these things I assume that having both an EBC and adjustable actuator is a waste?
Do most people who have EBCs just use the stock actuator anyway?
Pazz
Not knowing a lot about these things I assume that having both an EBC and adjustable actuator is a waste??
No, definetly not. The control over boost you get with an EBC can make a huge difference over an adjustable actuator only setup. Spool times, speed/rpm sensitive boost etc.
Yes, all you are doing with most forms of boost controller (electronic of manual) is fooling the actuator into believeing what boost is being run.
Darren_S15
18 January 2008
Essex, UK
Last weekend I decided to change my actuator for one a second hand one that was working correctly hoping to fix my low boost problem.
Sadly this has not solved my problems.
While I had my intake side of the turbo off I noticed a build up of black greasy/slimy stuff in the pipe so I cleaned this all out before I put it back together (guess the HKS it came with caused most of this?).
The car seems to pull a little more responsively, but still wont go above 0.5bar, although it does seem to get to 0.5 alot easier/quicker now.
Next Im going to try the boost solenoid as this is the other suggestion.
If it is not the solenoid what else could I try?
Is it possible one of my gaskets is leaking, or would this be quite noticeable?
If a gasket was leaking to the extent of only boosting 0.5 bar, you'd hear it! :nod:
Darren_S15
18 January 2008
Essex, UK
Can anyone tell me if there should be a constant voltage going to the solenoid while the engine is at idle, or is it a variable current?
When my engine is at idle there is nothing going to the solenoid.
