brake fluid
C
cloudandy
i've just found out that UK don't make DOT 3 brake oil which is the standard spec
for s15.
My fluids are running low at the moment and i just want to top it up to use for a few weeks.
Is it possible to mix abit of DOT 4 in there, which was told but halfords but the lid said something else.
thanks
Speedy
Im pretty sure they still make Dot 3 as we use it in work. I wouldnt mix the 2 fluids together i would bleed the system with fresh fluid. 5.1 is the better option but need replacing more frequently.
sushiming
13 November 2005
Hong Kong
yeh 5.1 thats whats going in mine on weds as iam having braided hoses fitted :D
You will find it difficult to get DOT3 nowadays. DOT4 is fully compatible with DOT3 standard (as is DOT5.1) and I wouldn't be surprised if that's what in the kines. You can mix DOT4 with DOT3, but its worth changing the fluid anyway.
Might be a good time to fit braided lines and get some DOT5.1 in there :)
oilman
12 October 2006
Uk
www.opieoils.co.uk
Dot3 is hard to comeby these days.
For reference all dot3 dot4 and dot5.1 will mix. The only ones that dont are dot5 and Castrol SRF.
Cheers
Guy.
20 October 2006
Poole Dorset
www.gtiroc.com
Oilman gets about :nod: Such a schlaaaag :thumbs: :thumbs: :thumbs: Here was me thinging you only gave us guys on GTIROC special priviliges ;) ;) :D
J.
S1Five
what actually does braided brake lines do to the brakes?
gives it a better/firmer feel?
atm i find my brakes to be ermm not progressive and i want a more firmer feel to the way the pedal feels when i step on it
:nod: firmer and more direct pedal feel. Putting some DOT 5.1 fluid in will help too. The biggest difference will be putting some decent pads on...
S1Five
well im currently using motul dot5.1 and ferodo ds2500 pads
so must b the lines ;)
Did you bleed the brakes for air :wack:
Yes, mate, you should notice a firmer pedal with braided all round and running that setup :thumbs:
S1Five
yeah of coz bled em
or maybe just worn pads now had em on for a while
