coilovers problem
sniffy
27 February 2007
Co.Wicklow Ireland
i was wondering if any one had any advice on how to unseize the coilover nuts the allow you to raise and lower the height as mine as seized and i need to raise it so sort out the camber.
B
Bry
Coat them in Duck oil and leave for a good few hours,they then should undo,the nuts may need a tap with a hammer and chisel just to get them started,just a tap though :wack:
if in doubt, give them a clout! :D
although, the tein C-spanners are good, cause you can put a 1/2" breaker bar on them to get more leverage... :)
K
kieran
clamp them in a vice and get huge set of stilsons on them lol bring out the animal in ya!
I ended up cutting off a spring seat and putting on a new one, as one had seized
sniffy
27 February 2007
Co.Wicklow Ireland
thanks for the advice lads going at this at the weekend so fingers crossed i can get them unseized
27 April 2006
Ireland
dont forget to clean the threads all the way down the coilover, a wire brush and some wd40 does a good job of it
