It was still on the original hard lines Jay, I never touched them while I had it. I did the ones on my old 180SX, and it was a right fiddly job!
Funny story about the rocker cover. I bought a spare to do off a S14 thinking they were the same. Spent time cleaning, stripping, smoothing, and painting and it only to find when I went to swap them over that they are different to S15 ones :annoyed:
They'll bolt on okay, but the coilpack holes are larger and the bit where the coilpack bolts down is lower, so when you put on S15 coil packs they were loose in the holes and would be bent over if you bolted them down. You could have bodged in a little spacer to make them sit right, but they would still be sloppy in the holes.
I wasn't happy doing that, so I only used the S14 one to cover the top of the engine while I did it all again using the original one off the car. All of the gaskets were new from Nissan when I did it, so they'll probably be okay to use again, as they're not that old.
Make sure it's a S15 one you get to replace it if you want it to fit right. Somebody might want a swap for their standard one perhaps?
Glad to hear it's running well
