david
Was told iv to only cut hole in battery tray for intercooler pipes but was lookin at the tray and under it is like the inner shell/valence. have i to cut true both or whats the story
Yep removed mine... only tack welded on... cut the support bit off then slid a chisel under then :wack:anyone actually removed the battery tray entirely... and have pics and info on best way to do it?
I haven't got any pics, I'm afraid. There was a template of SXOC, but I can't find it after a quick lookNicely would you have a picture of where yours is cut through the battery tray? regardless of what sort of intercooler it is, is the hole always cut roughly in the same place?
Where do u get that rubber gromit stuff for around the hole?
I did similar, but just used a bit of boost hose with a slice down it![]()
:wack:What does well for that is washing machine hose cut upon its length. Is very strong![]()
