Gearbox whine
4 January 2012
Cornwall
hiya.
i have used the search button but im still a bit confused as to what is exactly wrong and what i need to do to remedy it!
had a slight whine from the box, when pedal is up. now got a bit louder and can just hear it when driving. low gears.
so clutch release or input shaft bearing?, noise disappears when i press the clutch pedal all the way to the floor.
how easy is it to change these items? what will happen if left for a while?
cheers in advance
Burnsy
If it changes when you put your foot on the clutch, I would say it is the clutch throw out bearing. Unfortunately it is a gearbox off job. If you were going to change the clutch, that would be the time. Also do the input sheaft bearing as well.
4 January 2012
Cornwall
cheers for the reply bud, is it more cost effective to have the bearing and shaft changed on mine rather than a new box?
im perfectly happy with the 6sp, but if i had it out i would want to strengthen it so it could handle more power. rough figures what does a standard box take??
cheers
12 February 2009
South Wales, UK
350bhp-350lb/ft is about your limit on the six speed - no guarantees though some people are fine with more, some have problems below this level. Generally if you want these srt of power levels then and alternate box is required - look in the gearbox thread for loads of info!!
It's normal to have some noise from the box. Especially considering it's about 2ft from your ear with just a bit of fabric between you and it. The noise you hear is probably just the input shaft spinning.
I would just leave it and see what happens unless it's severely loud. By the time you've spent a fortune having the problem (which may not even exist) fixed, you could have bought another box..
21 March 2009
westhmeath ireland
Leave it alone bud, ive had a slight whine in mine from day one, still going strong over two years later
4 January 2012
Cornwall
cheers for the replies boys, i would leave it but its damn annoying! i can hear it clear as a bell outside the car.
my gearbox is definitely on the limit then! shes running 350 lb/ft! what are the options after this sort of power????
4 January 2012
Cornwall
standard, do have an exedy clutch ready to go in, came with the car and ive forgotten what Jez said what type it was!
