help help urgent
2wd
19 September 2014
Manchester
The garage are fitting the driftworks S14 conversion flywheel for the S15 my son has and the pilot bearing in he centre of the old DMF is stuck
they need this to fit the new one
does anyone know where I can get one from please
7 May 2009
Lecce ,Italy
Double check the DW flywheel as it should have the pilot bush already pressed in. In case it doesn't you should be able to find it on ebay or at any nissan parts shop, also it's the same as the s14.
Hope this helps
2wd
19 September 2014
Manchester
Thanks
I've been advised it's not there but we've managed to source on from Nissan
