Help me out guys
A
Audiiobahn
I need to know if the sr20de cylinder head as the same as sr20det cylinder head?
My friend wants to buy the cylinder head from my s15 spec-s to put in his S14a.
Will it works?
8 December 2010
Finland
Should fit, but I'm not sure if it has same valves as DET. Sell cams to me if they're ok :)
A
Audiiobahn
Thanks, Yes I can check the cams later!
22 October 2009
Paisley
www.bebo.com
Am not 100% sure they will am sure the det head has different porting on it? could be wrong though...I always though the easy way a to change from a DE to a DET would be just put on a turbo kit but they always seem to just change the whole engine thats whats making me think its not the same if you know what I mean :)
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
The DE+T does work but it's just a matter of mapping it correctly & keeping the boost low - there are plenty of lads in New Zealand that do it :thumbs: The reason why most people on Ireland / UK just do a swap is because there's no "tuners" that have any experience mapping DE+T's properly (that I know of) & DET's can be got relatively cheap....
As for the head, I have no idea :rolleyes:
13 June 2010
Pisa, Italy
www.flickr.com
The only difference in the DET and DE head is the size of the exhaust valve stems. The DET has 7mm valve stems and the DE is 6mm. The cams are different, DET are 240/9.5 and the DE cams are 248/10.5. You'll also have to swap the coolant neck for the turbo coolant line. The heads are 100% interchangeable though.
