How to set up the Z32 AFM to S15
MarcoS15
Hi
Anybody know how to setup the z32 AFM to S15 can build up more power.
Becasue I have already used the Z32 AFM now. But I feel that it is not much different as before (no Z32 AFM).
I have check that the AFM is correct. nismo 550cc. Andthen I have used the chip to upgrage in the org s15 computer. But the power is not same as I hear from anyother s15 ower.
Who can tell me why. Is that my chip setup not good?
Help!
Moved this to "mechanical & Bodywork" Although maybe it should be in "general" area?
You wont get a power upgrade from the Z32AFM unless you're stock AFM was maxing out.
The Z32AFM can cope with more air. that's it. If you have a chip which was made for the Z32AFM you're all good :)
sillbeers15
Z32 AFM, 550 injectors and a bigger fuel pump are supporting parts for a bigger than stock turbo (not that much bigger....<500hp at crank) to mate to your SR20DET with the need for a programable computer or programable chip.
With no turbo upgrade, it is redundent to have these parts changed. As a matter of fact, you should feel more slugish after installing them with no proper fuel and ignition map retune cause your A/F mixture should be richer than before.
You can't change the the AFM and injectors without a remap - full stop. It'll run like crap.
Standard AFM began maxing at the top end between 310-320bhp on my S14, and its the same AFM. Maxing = det.
MarcoS15
I have already change the HKS 2540 turbo.
andthen I have already install the Z32 AFM, 550 injectors and a bigger fuel pump and the chip. But I can feel and smell that the fuel is too rich.
I think the chip is not very good.
MarcoS15
The power is better than before. But I think it can be more powerful that if the fuel is not too rich. Becsaue it is too rich now.
24 February 2006
Plymouth
AFM isnt the way forward :no:
MAP sensor (PowerFc D-Jetro!) forever!!! :D
Though considerably more expensive... Z32 is perfectly up to the job so long as its a custom mapping :)
sillbeers15
Forget about chips unless you or whoever can reflash the memory after several dyno runs. It is out dated technology in tunning.
A programable ECM is what you need to tune your ride on dyno and road course if your aim is to have optimum power and fuel economy.
24 February 2006
Plymouth
:thumbs:
Hence go map sensor and PowerFc D-Jetro and get it tuned propely...
Or get a Z32 AFM, a HDev chip, get it tuned properly and spend the big wedge difference on more mods...
PFC is good, but not the only solution.
