Nickichi
- 13 March 2010
- Southampton, UK
- forum.s15oc.com
Heya, done a little searching through the older posts but I felt I needed some confirmation before I did any more Lifting
Since a pic speaks a thousand words you can see were I jacked the front up using the engine support bar which I believe is the front jacking point for the car according to the manual.
Is it possible to jack on the bar in front that im pointing to were the Rad sits as my jack is pretty much fully under the car to reach the normal spot. Read in someone's post about a front mount point so im guessing thats it.
Also is the rear diff safe to jack onto, its what im assuming the service book is pointing at for the rear lifting point
Thanks
Thanks
