Jacking Points
Nickichi
13 March 2010
Southampton, UK
forum.s15oc.com
Heya, done a little searching through the older posts but I felt I needed some confirmation before I did any more Lifting
Since a pic speaks a thousand words you can see were I jacked the front up using the engine support bar which I believe is the front jacking point for the car according to the manual.
Is it possible to jack on the bar in front that im pointing to were the Rad sits as my jack is pretty much fully under the car to reach the normal spot. Read in someone's post about a front mount point so im guessing thats it.
Also is the rear diff safe to jack onto, its what im assuming the service book is pointing at for the rear lifting point
Thanks
noooo, dont jack it up on the core support panel mate, it will just fold up. its only boxed mild steel plate and wont take the weight of the car.
sx-si
7 June 2008
hampshire uk
i jack mine there and its fine
does flex a little though
seriously - you're mad mate. i thought it would be like the chassis rails, made of cheese lol
sx-si
7 June 2008
hampshire uk
my chassis rails are mint too i jack on them
i never jack on the sill anymore
i just use a 20cm bit of long wood to spread the load and its mint
allough i can jack just using the end of the jack but the front bracing goes a bit flexie
i guess its more down to condition of car
i find the best places are the sills with the standard jack with a rag on it, leaves them unmarked, and the diff for the rear.... but if it works it works :)
sx-si
7 June 2008
hampshire uk
i went through my old s14a sill a few years ago and that shell had bearly any rust so i lerned my lesson there
24 November 2009
North Yorkshire
if you dont want to jack up on the sills i jacked mine up on part of the rear suspension support things.. dunno their name, but if you look by your rear suspension theres some flat bits that take the weight of the car when you drive it anyways, so anything around here is a safe bet! (just dont put the jack on your fuel tank hehe)
you can use a hydraulic jack on the sills too, just stick a lump of wood between the jacking plate and the sill to prevent any damage to it :)
If I jack the rear I always go for the Diff casing and take both sides up at once. If I do the front I use a big rubber pad adaptor on my jack and take a chassis rail or suspension part as they are both solid. The rad core support is only held onto the car by a few spot welds. I'm surprised the whole thing didn't just come off! :wack:
I try not to jack on sills as the jacking thin metal thing are all pretty much flattened and FUBAR'd lol :wack:
Rear diff casing like everyone else and more recently on the front I can get the bumper off fast so I go straight for the bit which I'm pretty certain is in the pic Nikichi posted the pic of... although when I checked this I thought it looks like the front subframe. I've jacked it where the pairs of bolts attach on each side rather than in between in the middle which does look like it can collapse lol...
