loss of power and noisy dont know why.??
15 August 2008
Ireland
Hello friends,
Im having a spot of trouble with my car and its really starting to annoy me. Sometimes when I start my car I have no power the car idles fine but shakes and backfires when I drive it. The car will drive but the turbo doesn’t kick and no acceleration in it. It might not happen for a few weeks but its happened twice in the last two days. Then if I park it up for 15mins the problem goes away (most of the times) and drives fine again for a few weeks.
It can happen if the car is started from cold and once happened while driving. I think its dirty petrol causing it to misfire but I don’t know if it is. I taught it should have cleared out by now but no joy. Any ideas of how to sort it are what is causing it would be great,
Thanks folks
dying coilpack could you the cause of your symptom's...
if it sounds like a subaru then its most likely a coilpack.remove the coil cover and leave it off, that way if and when it happens, whilst the fault is there, unplug each coil pack in turn one at a time, one of them will not have any effect on the engine note - thats the faulty one. exactly the same thing happened to mine. if it happens when the car is going along then drive it carefully off boost. mine was the rear most pack and from what i understand this is the most common to fail due to its position and the heat it is exposed to.....
just out of interest.. with the coilpacks, can you change them individually or do you have to do all 4 at once?
just the one thats dodgy needs sorting:)
15 August 2008
Ireland
ah fairplay lads saved me a mechanics bill, much appreciated
the SplitFire coil packs worth getting r just replace the faulty one??
splits will cost you about £250plus.... a single standard one is £55ish from nissan....
15 August 2008
Ireland
true but r they worth getting do you know???
Money's on the coil at the back of the engine ?
Thought i might also point out you need S15 coils, S14 ones wont fit.
15 August 2008
Ireland
problems got again but ill source a coilpack and when it happens again ill let ye know how it turns out.
thanks for the help
dss15
Let me know how this rolls..
I just experienced a good old power shudder today.
Intermittent - I thought it might be time for a new fuel filter, but we'll see if it happens again...
15 August 2008
Ireland
ten points to jez,
coilpack at the rear of the engine looks like the problem alright. i took it off when the problem was there then put it back on and problem went for a week. Just having trouble finding one, i wont lie havent looked to hard.ill get it sorted this weekend
Just put a post in the wanted section. If anyones upgraded to Spitfires they'll have 3 good ones still..
15 August 2008
Ireland
Got a coil pack off raystang. Cheers mate:thumbs:
it was the coilpack to the rear of the car, (closest to the windscreen)
And that has cured the problem!!!!:notworthy:
