FS: Nismo AFPR, fuel rail, OEM clutch & flywheel, throttle bodies, DET head
Max
31 October 2010
Cornwall
Custom Steel Top feed fuel rail for DET £60
has mounting pieces for DET rail, not pictured
AN6 in and out, for injectors with 11mm tops (blue InjectorDynamics ones)
(ignore the ID's, NOT FOR SALE)
Standard turbo inlet and outlet pipes with bolts/nuts £25
RB20E throttle body 60mm £20
same bolt pattern as standard, requires flipping over as throttle pulley is on the opposite side
SR20DET throttle body 50mm £10
S15 Spec R BMC £30
Might be after the head dude assuming its heavy when are you next up this way??
Max
31 October 2010
Cornwall
pictures added, prices dropped
Max
31 October 2010
Cornwall
Fuel rail still left
