On the OEM rear lights, are both bulbs for the side lights supposed to light up the second filament when you brake, or just one bulb on each side as I can't remember?
Cheers
Cheers
That is strange, yours have the fog light in standard don't they? Could it be possible they're wired up slightly differently? Clutching at straws there hoping something isn't going wrong! :/
That's what mine do, but Mike's above doesn't as they both glow. Both bulbs are 7443 "Dual Filament" bulbs so both should glow brighter when braking.In Both OEM rear lights, there are the following bulbs:
-1 bulb for night light
-1 bulb for night light with brake light in it
-1 bulb for reverse
-1 bulb for side indicator
You'll see i mensioned the first 2 bulbs with night light, both will glow when turned on the lights, only on of them will glow harder when you brake.
I see you wanna go back to OEM lights, i want to buy D-Max Led, maybe we can arrange something?
It depends if both have an brake wire, maybe mike's are looped.That's what mine do, but Mike's above doesn't as they both glow. Both bulbs are 7443 "Dual Filament" bulbs so both should glow brighter when braking.
I am keeping the D-MAX Led lights unfortunately :thumbs:
