Rims an sizes
H
Hawks
Right hi guys, I've just bought Rota force rims at 18 x 9J et 35 al round! There now going bac as I can't get them to fit at all on the front. I've a fairly standard specR with HSD's. Can someone help me with getting the perfect size rim for the fronts?? :s cheers
1 May 2010
Wolverhampton
What is stopping you fitting them on the front? hitting coilovers? rubbing arch? offest should be fine so could even use spacers and a bit of camber to get them clear and under...
H
Hawks
Yea even with 5mm spacers they still hit my coil overs and there to a point where not even stretched tyres will make it legal coz they stick out to far and I don't wana be going down the route of getting bigger arches?? :s
1 May 2010
Wolverhampton
Do HSDs stick out quite far then on S15s? Havent seen them in person..
I'd go for 10-15mm spacers and whack more neg camber on to tuck them under arches..
26 March 2012
et is way high, ideal for the front is 10-12, you could run a 25mm spacer, i have 9.5j et30 20mm spacer and a little camber. easily done
Mike
16 May 2010
I'm 90% percent sure my fronts are 18x8.5 et30 very close to coilovers but no issues at all.
As above I run 8.5 et 30 I have 3 mm spacer on mine though because my teins are huge and rub a little .
I would say for a 9 you would probably want et20
23 July 2010
SW London
I ran 9J fronts but had to lower the et down to +20 as the wider the rim the closer the inner edge sits to the strut. I ran 8.5j previously with et +30 adn the wheel cleared a lot more than the 9j.
H
Hawks
Yea I was thinking an 8/ 8.5J with et 30 might solve it. My hsd's do stick out quite a bit plus I only have standard tracking arms etc. What rims are you lot running on coz I definitely want 18s but found Rota can't help with the right offsets on 18's?? Cheers guys
Mike
16 May 2010
Rota Grid Drift, 18x8.5 et30 running HSD's also. Pic below on sig. :)
I've only had it rub when I lowered it to far.
H
Hawks
Nice mike! I take it that's at the front!? I'll post a closer pic again on the favourite pic section :) cheers
23 July 2010
SW London
I ran 18x9j et 20 front on hsd's, the car was pretty low with no outrageous camber and never rubbed, even on full lock. Ran 18x9.5j rear with et 45 but I had the run a low et to squeeze the 265 wide 888's in the arch.
Jay
6 February 2010
Peterborough
xxr 522's fronts are 18x8.5 et30, fitted with 235/40 tyres. 5mm spacer and im running tein control master coilovers and needed slight camber to tuck the wheels in the arches. no rubbing whatsoever.
H
Hawks
Ah cool I've been looking at xxr's what have yours been like? :)
