S14 Clutch > S15 Spec R??
8 December 2012
Surrey
Ive searched and cant find a definative answer.
please can someone who as actuallly done this or have any experience with this reply..
Can I go buy an S14 clutch kit (NOT flywheel) and fit it to a spec R 6 speed?
please no answers with my mates, dads, cousins, brother said you can/cant.... ive read all through that bollox all over google
thanks in advance
8 December 2012
Surrey
Yes you can, a lot of people do this including myself :)
So any s14 clutch yeh? Someone recently old me only certain ones but that makes no sense to me.
350lbft what clutch should I be looking at?
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
dude, an s15 has a duel mass flywheel. If you want to fit an s14 clutch then you would need to change the flywheel. BUT if J0R04N says hes done it on his then it must work.
I use an ORC 409 which has its own fly and twin plate setup. I know 100% they differ from 5 speed to 6 speed.
22 July 2010
And clutch choice all depends on your wallet size. I would look at the Exedy setups with the flywheels included or nismo copper mix. Or if your budget is lower like mine was I was advised the Exedy padle clutch. Little bit of a nuisance in traffic but you soon get used to it. The other option is the organic one. The only thing I was told is they will wear very fast when putting over 300bhp through them. However I don't know this for sure????
B9NKO
5 December 2010
Midlands
Any s14 clutch will fit on the s15 flywheel as I did it to mine
mattyb
28 October 2011
gateshead
Re: S14 Clutch > S15 Spec R??
If your buying a new one dude. Just near in mind that exedy clutch snd flywheel setup can effect end play on crankshaft and there pretty cack for road use. Ive read good things about coppermix and hks
Sent from my GT-I9300 using Tapatalk 2
I bought and fitted (myself) an S14 act heavy duty organic clutch (clutch cover and friction plate and release bearing).
Really good pedal and great bite. Dont buy an extreme act one thy are too harsh.
So to sum up YES a s14 CLUTCH kit will fit. A s14 flywheel WONT FIT!
