slammedmind Joined 27 April 2006 Messages 1,145 Reaction score 0 Points 0 Location Ireland 1 June 2008 #1 I know theyre both sr20det engines but im looking into a spare to rebuild from the s14. What will i have to change to get it to suit the s15?
Auss15 Joined 30 November 2007 Messages 2,152 Reaction score 0 Points 0 Location Sunny Tweed Heads 1 June 2008 #2 Not much, their pretty much identical. The main differences are in the gearbox and diff and other areas like body suspension IC etc.
slammedmind Joined 27 April 2006 Messages 1,145 Reaction score 0 Points 0 Location Ireland 1 June 2008 #3 Ok so would i have to use the s14 gearbox and clutch or would the s15 box and clutch go straight on?
DeanS15 My car is so clean you could eat off it. Joined 16 March 2008 Messages 2,977 Reaction score 4 Points 38 Location sheppey, kent Country 1 June 2008 #4 if the blocks are the same then the mounting points for the gearboxes should be the same as they are tapped into the block are they not? i think what was meant is that the gearbox is different as in internally - ratios/number of gears etc....
S screamracing Guest 27 June 2008 #5 also the s15 sr20s have vvt but other than that the engines are almost exact
