As above, does anyone know if s14 hand brake cables are the same as s15 ones??
or if there is a stronger alternitive..
With skyline brakes you need R33 GTS-T handbrake cables.Also on this, does anyone know if there are any SLIGHTLY shorter cables that fit the S15? i've got skyline brakes and the handbrake cable is too long so doesnt lock properly![]()
yeah i've got the individual cables from each corner connected already, but they join onto the ''master cable' if you will, which is connected to the actual pull part inside the cabin.. and its that front cable thats too long. wont the skyline variant of this one be too long also?With skyline brakes you need R33 GTS-T handbrake cables.
