s15 confusing bits HELP
sx-si
7 June 2008
hampshire uk
ok first whats the plug by the left of the rad?
anybody have issues with the standard boost gauge? mine turns its self off when it wants
how is the speed and sencors connected and where?
am i going to have issues if i change the diff to a 2way and remove the abs?
9 March 2008
Northampton
What is there not to like?
99.9% of the time you probably wouldn't know the car has ABS and that 0.1% it can save your life or at least your wallet.
I did a trackday with the Lancer Evo owners club a few years back and some guy thought it would be good to turn off his ABS. Surprise surprise braking for the last corner (in front of all the spectators) he locked up and crashed into the barriers...
H
Hotrodstu77
I took abs outta my car and now I wish I hadn't. Used to have it in my old s13 and now I miss it.
sx-si
7 June 2008
hampshire uk
because nyour preciouse abs doesnt work going backwards ;)
ive spent the last 4 years driving 200sx's without abs and thats the way i like them
compeated in them and done a hell of alot of trackdays and i just dont like it
nothing worse than spinning your car drifting or on track and the brakes dont work
anyway its getting removed and not the question ive been asking :)
japmadlad
28 June 2007
Armagh, N.Ireland
NOT SURE ITS NOT USED
anybody have issues with the standard boost gauge? mine turns its self off when it wants.
LOOSE WIRE? UPGRADE IT, STANDARD ARE CRAP.
OFF GEARBOX
NO, SHOULDN'T THINK SO
28 July 2009
Hertfordshire
Im sure the speed is read off the ABS, can someone confirm this?
H
Hotrodstu77
The s13 and s14 are off the tranny on both motors so I doubt they change it on the s15
jspecv20
SX-SI,
The speed is measured from a sensor plugged into the diff housing (this is also one of the ABS sensors)
Some people just remove the ABS fuse for track days etc, (this also disables speedo and the odo)
Changing diff centres/ ratios won't have any effect on ABS, removed or not.
sx-si
7 June 2008
hampshire uk
jap mad lad your a ledgend
apparently the speed sencor is diffrent on older and newer s15s
few tuning garages have said diff housing by the prop and others have said gearbox
ill find mine next5 week when im putting on larger breaks and a lot of goodies
thanks for your help
29 September 2009
speed readings are taken from the ABS sensors back to ECU then to dashboard.
sx-si
7 June 2008
hampshire uk
hey roachey thanks man :) so the abs unit isnt even needed
you loioking for a s15 now dude?
The solenoid next to the rad is part of the emissions control. It's slightly different to the S14 (which does it all via the carbon canister). The S15 canister is smaller and doesn't take a boost reading. The solenoid does this and also works as a valve. This is on the JDM S15s. The ADM S15s have the same setup as the S14.
