s15-s brakes
C
cloudandy
hi all
Does anyone know where i can get replacement for s15 spec-s brake discs or
upgraded ones asap?
thanks
andy
I believe the discs are the same as one of the Primeras...
Why not upgrade to four pots and something like 310/315mm discs? I'm sure you could get a set of S14 callipers off SXOC fairly easily :)
I have a set of S15 Spec R calipers that might be for sale in the next week or so:) I can let you know if you want :)
C
cloudandy
hi
thanks for the info guys, i spoke to bren from apexi and he said it
should be the same as the s14 rear brakes as well.
I'll see if its going to be ok to change the pads first, to use for now.
Otherwise i will need an upgrade soon anyway,since i've got the
sr20det engine running now.
Yeah, let me know next week mate if you do have them for sale, i'll let
you know if i need it then.
cheers
andy
:nod: The Spec R discs and callipers are the same as the Euro S14/a. The Spec S fronts aren't though...
You should have upgraded the brakes when you did the engine. The S14/Spec R 280mm/four pot setup is the VERY MINIMUM you should be running...
*cough* HERE HERE!
;) :D
C
cloudandy
thanks for the advice, i have another problem and found out my rear brake hubs and nuts are wearing off and needs changing asap.
I would like to find out if the s15 Spec S rear brakes hubs and nuts are the same as s14 so i can replace them quickly?
thanks
The entire rear brake and hub setup is the same across all the S15 and S14 range. Some of the original PNs may differ, but they were superseded by the S15 PNs. This means they are the same.
C
cloudandy
many thanks nicely!!
