FS: SR20DE engine from S15
mitch
93K on the clock, but I'm not sure how many are KMs and how many miles. This engine was running fine and was removed from my S15 to replace it with a DET engine from an S14.
Comes as it was lifted, minus the inlet manifold, but I do have an S14 manifold which is pretty much the same, and also the original injectors on the fuel rail. No flywheel, though I have a secondhand S14 one that I can throw in. I also have the ECU, AFM and wiring loom if required.
Cams are still fitted, as is distributor. If it doesn't sell, I think I'll keep the VVT and hope it's the same as the SR20DET one. The solenoid is there, so I assume the pulley assembly is too though the rocker cover hasn't been off.
?220 or near offer collected from Bicester, Oxfordshire (J9 M40)
Thanks
V
V-MAX
I might be interested in this?
Nah just kidding... Iv'e already got one
free bump, good luck with the sale...
Saleh_
would u sell the exhaust manifold? if u still have thank you
