Top dead centre?
21 July 2009
United Kingdom
Hello :)
I'm hoping one of my fellow boost brothers can help me out here...
I read that before i take off the cylinder head (car is a JDM spec R) that you need to set the engine so that cylinder 1 is at TDC.
I ***think*** i've got mines set ok but would like someone or a few of you to confirm for me.
Thats obviously the crank pully and this one is the sprockets:
Ive lined up the yellow link with the dot on the inlet sprocket but i was expecting another yellow link to mate up with the dot on the exhaust sprocket :S
Theres only one coloured link on the whole chain :s
Any guidance would be greatly appreciated :)
24 November 2009
North Yorkshire
This link is not related really, but may help:
http://www.frsport.com/How-To-Set-Crank-Angle-Sensor--CAS--Timing-on-the-SR20DET-Engine_t_25.html
For me to find TDC i just stuck a straight bar down the first cylinder, and turned the engine over by hand until the bar was at its highest point, carefully marking the bar with a pen everytime you moved it so you could work out what its highest point was.. i couldnt tell you 100% which notch is TDC though i'm afraid..
21 July 2009
United Kingdom
Thats a good read :nod: bookmarked that one :thumbs:
See what i mean about that chain having two dark links to match up the notches though?
Unless the S15 has a different chain or whatever but surely not :confused:
STF515
The way I make sure that you have it on TDC number one is to watch the rear (#4) rockers, one side should be opening, the other should be closing. If you have the number 1 valves moving, you are on TDC number 4. Hope that helps. I normally unbolt the sprockets off the cams, and ziptie the chain to make sure you dont upset timing, saves a little bit of time :)
Steph
