torquing up rear alignment arms
21 July 2009
United Kingdom
Hey guys, i know a couple of you have done the same job as i'm in the middle of- poly bushing (etc) the rear subframe.
Now in the next day or two i'm -hopefully- going to be fitting my new bushed alignment arms i got from Apex.
Someone told me that they need to be torqued up with load on them i.e the car on the ground. Did you guys do this or can it maybe be done by jacking up the rear of the car from the diff? :confused:
Or can i just torque them whilst the subframe is off the car :confused:
Does anyone know what torque the arms need and also the four main mounts that hold the subframe to the car?
cheers in advance :)
28 July 2009
Hertfordshire
Says in the workshop manual that they need to be torqued with load on them. I used 4 spare wheels and placed them flat under the wheels on the car so I could get under while the arms were under load.
i'm gonna do the same as andeep did, block the wheels up and sit the car on them before tightening. also make sure that any ride height adjustments are all done before doing this. you will find that if you tighten them before the car goes on the ground the back end will be a bit more 'springy/bouncy'. as for torque ratings, i've had mine off numerous times and always done them up tight just on a spanner, maybe a couple of final taps on the spanner with a rubber mallet if you're worried. i'm not recommending you do this, i'm just saying its always been fine for me with no probs whatsoever (thats my little disclaimer lol)
21 July 2009
United Kingdom
Ah ok good idea using spare wheels :nod: I have a pit at the side of the drive so that could be a shout.
So tighten the arms by finger whilst the sub frame is off then once its back on the car and under load tighten it using a ratchet or whatever?
yep, finger tighten the nuts provided the bolt is all the way through. you dont want to be pulling the bolt through by tightening the nut with load on the things :)
21 July 2009
United Kingdom
Got you :thumbs:
Just need to figure out how to remove the stock rear control arm bushes and replace them with orange DW jobbies!
I'll report back if i cant work it out and/or break something :wack:
From memory, I did mine with the wheels off the ground. They haven't fallen off yet. I wouldn't think it would make much difference to the torque on the bolts if the wheels were loaded or not.
I nipped mine up with them in the air and had the alignment guys adjust/tighten them yesterday. They did them with load on.
1 May 2010
Wolverhampton
Would thi sbe the same for standard items?
I will be removing everything from the subframe as it will get coated so putting them all back on would it be better to tighten them like the method above?
its more important to do it with the standard arms when loaded up or it will stress the bushes out to the point of knackering them :)
I used A-Line but it will have to go back to get re checked as it's pulling to the left slightly now and was perfect before..
28 July 2009
Hertfordshire
As said, it's important to torque the arms when the suspension is under load when using bushed alignment arms.
If you are using rose joints, you can torque them when the suspension is not under load.
5 October 2009
Thats a shame Craig, mine is so much better since.. hope u get it sorted soon..
