Turbo Drain Pipe
31 August 2007
Ashton, Manchester
Im having real trouble getting a new Turbo Oil return pipe, have been to Nissan and there not sure so wont commit to buying it in for me. They gave me 2 numbers the first, 15198-69F00, they say its not available. The second, 15198-75F00, they can get but there not sure its correct and its £23 + vat.
Does anyone know which one is correct or where I can get one ASAP as mine is split and sprays out oil under high revs or constant drip when driven boringly, lol. HELP!!!!!! Will also require new heat shields as I know some come without them.:D
mattyb
28 October 2011
gateshead
can yo not repair yours with a small tack welds just turn the welder down.
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
Why not replace the standard hoses with braided lines?
Such as: hoses
If your going to the effort of taking the turbo off might as well make sure you wont ever have to do it again :)
Darren_S15
18 January 2008
Essex, UK
My bad, Ive just seen your after the return, not the feed as in the braided line kits Ive linked to.
Never had to replace this myself Im affraid.
I assume this part is the same as the oil return for any SR20DET?, could you not find a breaking S body and get one?
If it's the rubber section split, just get a replacement rubber hose of the same bore from a motor factors and cut it to size... Can't see how the metal part can split??
What's the bore? I think it's about 15 mm same as the rockers. If that's the case, I've got a length of unused stainless braided oil hose I'll send you for 15 quid all in... I'll even throw in a couple of stainless hose clips if I've still got some ;)
31 August 2007
Ashton, Manchester
I will check if I can get under the car damn its so bleeding low lol:p
