- 26 October 2005
- Helsinki, Finland
- www.jull.net
I've posted this in several places, but still can't establish the problem...
Don't know if anyone else has this happen...
I appear to get two levels of boost when me foot is to the floor. I get a nice level amount of boost up to about 4500 rpm, then it suddenly leaps up to a more unpredictable level.
I'm running an SBC iD-3, but it does it when just using the adjustable actuator.
Refitting the carbon canister and plumbing its sensor back in (something not fitted on the ADM S15s) stabilized the boost somewhat. However, its still spiking.
Checked for boost leaks, controller (turned off), and actuator (replaced) - still does it. Even when running on adjustable actuator only.
Appears to hold boost fine up to 0.9-1 bar, after which it suddenly goes nuts on WOT.
Its been suggested that the internal wastegate might be struggling and that an external might sort it. Can't understand why this would be a problem on the standard BB turbo...
LATEST:
For no explicable reason, my boost appears to have stabilised at around 1 bar over the last two days - without me doing anything.
This is running a boost setting of 53/4 (can't remember) and 0 gain. I tried adding a gain of 7 to experiment this morning, and it immediately spiked the next time I overtook. Back to 0 and its fine again.
This is bizzare because it was running exactly the same settings last week and was still spiking...
Any idea how to make it more level (without changing turbo
)? A gain of 7 on the SBD i-D3 is fairly standard.
LATEST:
