Backlash on driveshaft
3 March 2010
sweden
Hey ya all..
I was on a car inspection a while ago. the inspector felt on the driveshaft and there was a slight play,not much.. He said to me not to worry.. but I want to check anyway..
Is that common on S15....??
Best regards T.M
3 March 2010
sweden
Just my S15 that's got this..?? =(
How much play is in the shaft? I expect there is always going to be some play in them,so long as they are quiet(not clunking) I wouldn't worry too much mate.
I have a different problem with mine,when you turn the prop one driveshaft pushes about 2 inches out of the casing and then engages.
Not what you expect after spending a lot of money having a new helical fitted lol
Luckily I have a spare diff to swap to.
3 March 2010
sweden
Ok,, Thx.. There's very little play. and no sound at all.. but sometimes when I take of slow.. I hear just ONE click.. nothing else..
I cant push the shaft backwards or forward.. just little play when i roll It..
Damn that's not fun when It pushes out..
No not at all,when I go into gear it takes a little while to take up the slack and set in place,got a skyline 4.1 diff to go on so that should be more fun!
I wouldn't worry too much tbh doesn't sound like anything wrong-f it gets worse /louder or more frequent then maybe have it checked over again.
sands
11 April 2008
kilkenny, ireland
I had that click in mine when setting off was sure a drive was on it's way out turned out the drive nut had came louse some how worth a try, got rid of my click
3 March 2010
sweden
Do you mean the nut on rear wheels..??
i'll check that this weekend =).. thx
JapanS15
I think he meant a nut on the driveshaft...where it connects to the diff.
sands
11 April 2008
kilkenny, ireland
The big nut on the nub, out side of the drive shaft 32 i think it is, thats what is was on mine worth a try
3 March 2010
sweden
OK.. Is the nut anywhere in pic..??
sands
11 April 2008
kilkenny, ireland
no, the nut im talking about will be under the center cap of your wheel pop off the center cap and you will see it
3 March 2010
sweden
aaah ok! thx..
3 March 2010
sweden
=) just were in garage and the nut on left wheel was tightened like hell,, but the right side, drivers side was very very, extremly little loose dont think It makes a difference but I tightened It as hard I could, then tomorrow I'll test the car.. =).. thanks for the help guys..
