what boost
28 August 2006
sheffield,south yorkshire
Car is fitted with walbro, grade 7 plugs, fmic, full stainless system inc manifold/elbow, z32 fuel filter, air filter and optimax. What boost should be safely run on stock s15 ecu. next on the list is horsham ecu upgrade
Hard to say really as all cars run differently. I ran .9 bar without a map and it was running rich so had no problems.
Jay
6 February 2010
Peterborough
i would leave it reasonably stock until ecu upgrade. as craig says, all cars run differently from factory, so to avoid future problems, wait till the car is getting mapped then decide what it feels "comfortable" running at. (personally i woulda waited till mapping before fitting walbro too, but thats just me!).
once mapped then stock tubby could see 1.3 bar of boost safely depending on who you talk to, at which point injectors and afm will be maxxed out anyway....
28 August 2006
what should stock boost be on an s15.is it same as a uk 14a
CMR
22 August 2011
Yorkshire, UK
It's 0.6 on JDM s15's
drifter
4 April 2011
Norfolk
I ran 1bar on mine before I swapped everything over, no problems at all
24 November 2009
North Yorkshire
Up to 0.7 on JDM models. Depends on your car.
Mine ran at 0.7, then as parts wore out it dropped down to 0.5 lol
But definitely no higher than 0.7.
I'm running 0.9 on mine now with FMIC, air filter, manifold, walbro, HKS actuator, & EBC. Runs a little rich, but no problems :)
CMR
22 August 2011
Yorkshire, UK
Yeah mine runs at 0.7, but that's with a catback exhaust which will always raise the boost slightly.
Havoc
27 March 2010
Portsmouth
LOL I use to run 1.3 and did so for about a year, as was recommended 'max' boost to me by Horsham developments. Went to countless drift days and never had a single problem tbh, now I'm running 1.2 as running a different setup.
Thats with, walbro, FMIC, iridium cold 7's, blitz intake, with 3" pipes to home! All on the standard s15 spec r learnable ecu, without getting fuel cut or miss fires. :thumbs:
Jay
6 February 2010
Peterborough
i suppose the thing to remember here is how much of a risk do you want to take with the reliability of your car? many people will tell you "i ran such and such without problems", and that may well be the case. but just because a car runs well now, the things we do to our cars could shorten the life of the engine. i have prematurely killed several cars in my younger years by shortcuts in tuning. lessons learned the expensive way!
my advice would be this.... if its your intention to upgrade your ecu in the near future, then wait till the mapping before any major boost increase.
