Pazz
If you went for the +30 they would stick out another 2mm over the +32's. But then the flip side is that you gain 2mm inner clearance from the coilover.*I noticed that Nicley runs 18x8.5 +32 on the fronts but also mentions the wheels do stick out a bit.
So if the +32 are going to give me possible clearance problems with the coilovers and stick out I think Id be better to be sensible and get the +30.
Thanks.
* = Assuming same tyre + rim
