Mechanical or Electric Boost Gauge
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
Just wondered if people have mechanical or electric after market boost gauges on their cars?
The one I'm looking at comes in both and I don't know which one to get..
Is one better than the other etc...?
Any info would be great.
_Wing_
go for electric, it saves you having to run a vacuum/boost line all the way into the cabin which saves headaches if the line gets nicked/bent/cut :)
I was speaking to Jez at HD about this and he said to me that mech ones are only good up to 0.9 - 1.0bar, so it depends what boost you want to run..
Darren_S15
18 January 2008
Essex, UK
Ill be going for a map at 1.2 bar I would think.
I'm going to need to run a boost hose into the cabin anyway for the EBC, but I guess having to run it up the A pilar could be a pain?​
you shouldn't need to run a boost line into the car for an EBC, you'll have a solenoid that's under the bonnet then a wire connecting your 2 units.
ebc's are better cause they can adjust slightly to make sure no spikes are had!
Darren_S15
18 January 2008
Essex, UK
The Greddy Profec Spec B II requires a boost hose taped into the FPR hose according to the manual I've read.
Unless I've misread it?
Yeah not sure bout other ebc but the profecBII you actually need a boost source so a vacuum hose needs to come into the cabin... But electronic definately!
More accurate and safer(in a way) :p
don't they have solenoids under the bonnet? that's where the boost feeds go?
the solenoid only controls the wastegate, it is sent a signal from the control unit which monitors the boost:nod:.
my hks one just had all of them to the solenoid.
It doesnt need to come into the cabin as you have a boost sensor that you can plug into the engine bay an dthen run a wire to the controller. Im sure ive shown you mine before ? :confused:.
As said though go for an electonic boost gauge.
i thought that would be how it'd go. just i've not seen the profec to argue.
i know that the HKS i had was 3 connections, vacume, boost and actuator feed. all were under the bonnet with a cable from the controller to the solenoid.
Hi Jez,
Can you explain more? I dont quite get it, where in the controller does it take the boost sensor input by wires?
Wait...i think im going crazy, maybe im now getting confused with my boost gauge. Im going to pop outside and check....
...just checked and indeed there is a boost hose T'd off from the FPR hose going into the boost controller in the cabin. Near the firewall ive T'd off again with a small length of hose to my electronic boost sensor so i only have 1 hose going into the cabin.
Everything works fine this way.
