9.5J ET12 on s15?
C
CillianS14a
Hello fellas,
Just a quick question for you wheel gurus, i know that the s15 arches are smaller than s14 ones but would a set of Rota GTR's in 9.5 ET12 fit under standard arches on an s15?
Or will they require a big stretch and a roll or flare?
Thanks for the help.
Cillian
I wouldn't have thought so mate, I have et30 on mine and they stick out a bit,depends though I guess if you ran a fair bit of camber you would get them in there,look in the wheel fitment guide sure there will be someone there who has tried it.
C
CillianS14a
Thanks for the reply, yeah i reckoned the offsets were a bit strong alright. Didn't spot the wheel fitment guide, i'll go check on that now.
Thanks.
N
nermz
youll prob need camber, stretch, deffinently roll and most likely slight pull on the rears. fronts no chance.
23 July 2010
SW London
This was the result of my 9.5j et 12 rotas with a 225 wide tyre. I sold them a week later.
I can't see the pics Adam has put up (work PC boo!!)... but I was running 9.5J +30 Rota GTR's on the S15 and for starters this required 15mm spacers on the front so with +12 you are sticking +3mm further out than the setup I had...
As most people have said I think the answer is 'no' unless you are willing to mess about with ridiculous camber, stretch and arch roll :wack:
29 October 2010
Dorset
They fit fine on mine 9.5j et12 allround 225 stretch on the front no arch roll or camber. Rears rolled and Cambered with 235 stretch
29 October 2010
Dorset
Here's some pics wheels are SSR professors
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
As above, I don't think you'll get away with it without some serious suspension set up or rolled arches. I did a trackday with a set of 17x9JJ ET 17 all round, I had Toyo R888 in 225/45r17 all round & it stripped the front wheel arch on the drivers side but no other issues...
Man I miss that car :cry:
29 October 2010
Dorset
If you like the wheels enough make the car fit the wheels. Don't settle on wheels you don't want just because they fit straight on! Wheels can make or brake the look of the car
29 April 2009
Im running 17x9.5 up front. Effective offset is et+10. -2.5 degrees camber. Federal 595, 215/40. Even like that, theres huge amounts of grip :)
