Noticed this today, I thought I'd give it some as I rarely get the opportunity to.
So I was giving it the heavy and when in the high RPM's between 5/7k I would try and change from 4th to 5th....Nope, The shifter acted like the gear wasn't even there, wouldn't go up.
So I had an idea! 6th I thought....Grind...Grind...It just wouldn't go in either, Not until the revs dropped.
At any other speed or situation its fine, It not intermittent. but purely trying to change from 4th to either of these gears at a RPM is impossible.
Any ideas what could be causing this?![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
