HELP! ... with ESVA
13 November 2006
Swindon, UK
Hi all, i've got a bit of a problem. Nicely generously lent me his front bumper so as to get the car through the ESVA, but i went to fit it and found a little problem.
Does anyone have the two front bumper reinforcement assemblies and the undercover bumper fascia. I'm really stuck here as this is a show stopper as these are part of the cars crumple zone and is on the model report.
Has anyone got these that i can buy or borrow? Thanks.
Also, where can i get these new? What part numbers are they.
They are 7 and 8 in the image below.
Cheers guys
Also posted on sxoc.[/img]
Number 8: 62030-85F00
Number 7 is a bolt. Did you mean the bar above no 8?
If that's the case it's 62290-85F00 :)
13 November 2006
Swindon, UK
Also, has anyone got an S15 undertray? I take it this extends all the way out the the bumper? It seems to go up when it get to the bumper and the s14 one doesn't, so i cannot use the one i have and it is a critical part of the ESVA test.
With the standard bumper, it won't attach if you've got an FMIC. It has to be trimmed. The Aero bumper (and aftermarket too) sits lower allowing the tray to attach over the FMIC.
13 November 2006
Swindon, UK
I've sourced the top bit, but still need the bumper reinforcement bar (8). Any got one they want to sell, lend?
Found it on japanparts.com and it's ?66 but it's an extra ?200 for shipping :eek:. I just need one to get through the test.
Oh yeah anyone got an undertray as well?
i think my undertray was thrown out the other week, left it in a mates garage after fitting the FMIC, i'll ask for ya though if it's still there...
Have you tried http://www.euroautosalvage.co.uk/salvage.htm?
Dammit! I've been after a replacement since fitting the Aero bumper. You really should run with it. It makes a considerable difference to the flow through the FMIC...
how can that be the case? the FMIC is firstly above the tray, and infront of...
once the air has passed through, more air is passing though already. the tray doesn't force air up...?
Air flow. Don't ask me to explain the aerodynamics. All I know is that its been tested with and without an undertray and it definitely makes a difference. Add a cooling panel on the top and its even better.
13 November 2006
Swindon, UK
I'm going to test fit an S14 tray to my S15. This due to the fact that the S14 tray is flat and would not need cutting. I'll let you know how it goes.
I've managed to source both the bumper iron parts. Got the upper bit and the lower bit should be on its way soon.
The S14 tray will need adapting. It fits all the way across, whereas the S15 tray is just the centre section with the two arch liner extending to the front bumper either side of it. The S14a bumper sits further forward too...
