Steering rack bushings and tie rods (S14 and S15)
E
Endless
Hi all, just wondering, can the aftermarket steering rack bushings and tie rods made for the S14 fit S15 as well? and are most of the suspension parts the same between S14 and S15? Also, anyone try the Energy Suspension bushings? they seems to be much cheaper than the Nismo ones, are the quality similar? thanks.
S13 tie rod ends and S14 rack bushes! :)
S14 bushes for suspension parts. :)
You can replace the complete rod and rod end as if it was for an S14 - if that helps.
As far as Ive seen so far, all Nissan R body and S body have the same threads in the rack (to fit rods) and they also have the same sized hole on the hub for the rod end.
FOr example, I run R32 GTR rods and ends on my S14with 6mm spacers each side (same as Tein) - cos its exactly the same as the Tein stuff, but cost me ?50 instead of ?lots! :thumbs:
