Track worthy S15
23 July 2010
SW London
No idea what happened yet, mate. I think it may have been an oil supply problem at the moment as I didn't use my original oil feed pipe. I'm getting the car back on the ramp tonight but feel a bit deflated after all this happening again in such a short space of time. I'll crack on with it tomorrow. The sump is coming off to check the strainer isn't blocked aswell. I'm about to lose £60 worth of engine oil aswell, bad times
I've sent the compressor wheel for the old turbo to a billet wheel company in Japan to get them manufactured but that's going to be a while. We also came to realise the car is crying out for a set of cams, they are indeed standard at the moment. We tried to run the car at 2 bar and it was extremely quick but we had to lower the boost due to possible valve bounce. So cams and springs are in order for it aswell.
Nightmare Adam!! Two turbos gone bust already?! Do you reckon something seriously is wrong with the oil supply to turbo or is it the fin's again?
23 July 2010
SW London
I can't say for definate but the compressor wheel has made contact with the housing. There were no oil supply problems with the last turbo and that's the only thing I can se causing a problem that's been changed. I'll be stripping the turbo down in the next day or so, so all will be revealed.
No!!!!!!!!!!!!!!!
:( not again man!!!
At least you know it's gonna be worth it when it's done!
What cams etc you going for!??
Can't believe it's happened again man gutted for you
eiden88
7 May 2009
Lecce ,Italy
1.9 bar :eek: ..and I thought my friend's evo was super-high at 1.6 :notworthy: ...Gutted gt35 is already gone, hope you can fix it easy,quick and cheap :thumbs:
17 September 2012
England
1.9 bar haha thats cool :cool: so you own a rocket ship then lol and everything loses in your mirrors lol, sorry to here bout the turbo going mate hope you get it sorted soon enough for your self and like peglio said least you no what your have when its rolling again mate, hope your ok for a daily drive car
23 July 2010
SW London
I've only gone 300 miles in the car since I bought it two months ago and 150 of that was driving to get the car mapped on Monday, lol, so I'm.desperate to use it properly.
I've literally just ordered GSC S2 cams, bc springs and titanium retainers for it from the States but unsure of when they'll be here. That'll allow me to raise the rev limit from 7500rpm to 8500rpm straight away and give me a good hike in power as the gsr cams are pretty ****.
Sweet little upgrade then dude! Be revving like a Honda on steroids lmao
Can't believe only 300 miles since you bought it that's crazy man! Hope it will be more reliable once it's built this time!!
23 July 2010
SW London
Yeah, it really needs a higher rev limit to be honest as it bangs through the gears at such high boost levels and on the gt35r. I only had a 2500rpm power band as we were hitting full boost at 5k rpm. As soon as it came on boost in 1st-3rd you almost had to short shift it as it revved so quickly. I don't need to touch the head now after buying the cams as the 4g63 head flows so well as standard you only need to start opening it up at 650bhp, it's almost like having a VET head as standard.
I'll be glad to get rid of the screamer pipe though, really didn't like the sound of it.
23 July 2010
SW London
Well I finally got the turbo apart earlier, I was going to do it on Saturday but decided to stay in bed. It's clear what's happened but to be honest I'm unsure if this has happened while fitted to my car or the previous owners car, I'm a tad more inclined to think the exhaust wheel damage happened on the guy I got the turbo off car and the last little push while we mapped my car finished it off.
I don't think it was an oil related failure now, it just seems like the exhaust wheel damage has caused a huge imbalance in the shaft assembly and the rear cartridge has destroyed itself resulting in parts of the car quite possibly being in the sump, as there's a few bits that are unaccounted for. More work is to come yet but not much will happen for the next couple of weeks I reckon. Anyway, here's what I was left with once I took the turbo apart...
17 February 2012
Southwest, UK
That looks pretty bad. Shame you haven't really had chance to enjoy the new car.
I'm sure it'll beepic when it's sorted.
17 September 2012
England
iam really sorry to see that happen to you, it wouldn't of damaged the engine would it? :( hope you get it sorted ok
23 July 2010
SW London
Cheers for the support, chaps. My new billet wheel arrived today in the mail, it looks like it'll flow well but it and the compressor housing need some machine work to go together well. I could of had the car running this weeki but I'm away with the other half and the cams haven't arrived yet so it'll have to wait another week.
This is the new wheel again the 35r 82mm wheel...
17 September 2012
England
pleased to see your getting there with it Adam, bet you cant wait to drive it again :)
23 July 2010
SW London
A little more has happened with this. I had some more time to strip the oil restrisctor out of the rollerbearing core and the main oil supply did indeed have a very small shard of swarf blocking it partially. So the turbo suffered from two faults... That doesn't really help me out, but it just lets me know exactly what's going on. The swarf was definatley not from my engine as I inspected the previous bearings and there was no contamination marks after the 3.5k miles it had done.
Anyway, engine work has started, I took the sump off a couple of days ago, the oil pick up was holding the rest of the turbo internals that were missing (no pictures though). The sump had so much sealer used on it it had a huge thick rim sitting on the inside edge:eek:, I'm actually suprised none of it broke away. That's not the best bit, half the sump screws were finger tight, only being held in with the sump sealer. It's a good job I work on my own cars, I'm very particular and always double check everything (shame I didn't check the last turbo though, serious rookie mistake:D).
To move things on... The cams I ordered were on back order even from the manufacturers, so I changed my order to the slightly more expensive but boldly quoted ''the best'' 272 cams available on the market from Kelford, which arrived with a reduced vat bill earlier in the week...
I actually saw a rolling road printout for an Evo earlier with the same spec engine as me, with these cams and the same turbo I'm running making 540bhp at 1.8 bar. The turbo is actually rated at 56lb per min, so roughly 560bhp max. If it is accurate, which I won't be willing to say it is, I could be looking at roughly that figure as I'm planning to run more boost.
One other thing I noticed while the sump was off is the engine has 1200bhp rated rods in it:wack:. I had to do a bit of searching to see what spec they were, as I have no receipts for the parts, just the engine build itself. It does indeed have forged rods, pretty bloody expensive ones too, and forged pistons at least, lol. It also has the uprated Mitsubishi headgasket which has been classed better than a lot of the aftermarket ones.
Nice!! So in some ways bad but in some good! Love little bonuses like that! At least you know the engine will be up to task! Glad it wasn't any worse......
I try and do as much work on mine myself now too mate as then you know exactly where you stand. If its something I can't do then I get polo involved lol that's some decent power your gonna be running then mate, what sort of torque figures you gonna be looking at with that set up?? Will be like my mates evo 5 spinning all 4 wheels in 4th lmao
23 July 2010
SW London
Yeah, it's not all bad, mate. I now know for sure what the engine is capable of. Hopefully I'll see some markings on the piston crowns once I get the head off at the weekend as I can't see **** from the underside of them, just to identify what make they are. Forged pistons aren't exactly poorly made but from the spec of the rods I can't see them being cheap ones... It's funny though, I go on the MLR pretty much every day and for the amount of member that club has and has had over the years it's the biggest load of **** I've ever witnessed! I've tried to find some tech threads on a few bits in the last couple of months and I couldn't even explain how many threads have had replies with ''speak to your tuner, mate''. That club is full to the brim with some of the most ignorant, idiotic, wasteful people I've ever come across. It annoys me how pathetic it is.
Slight, rant:D. Chris, no idea on torque figures but the Evo engine is very torquey anyway and tends to produce torque figures near bhp unless running very large turbo's.
17 September 2012
England
Adam iam so pleased for you mate and its nice peace of mind to no your cars built properly cause you done it and not a grease monkey. and 500+bhp :) :D :thumbs: yeah now that's really serious, i always think evos are like them monsters you get scared of when your little that you think are lurking under the bed, there scary, mean looking and savagely fast, sometimes i really wish i had an evo. and sorry to here bout the MLR site i do think its quiet amazing how many nice people there are on this site as odds say that out of set mount of people so many should be numptys, umm hang on though i come on this site don't i lol :p
23 July 2010
SW London
Luke, I work for a well respected engineering company and I genuinley spend my living telling mechanics how to do their job properly. So I never let anyone touch my cars except me.
You wouldn't beleive the **** I got off my boss after the second turbo blew up though:wack:. He gave me a lecture on everything I know and missed the most basic operation.... I went and ordered myself a bouquets of woopsy daisy's:D
