WTB: Windscreen washer PUMP
immy21
9 November 2012
Edinburgh
As title I'm after a front windscreen washer pump for my S15 R, I'm sure S15 S will use the same pump but s14a pumps are different.
The front screen pump is the right of the two when looking at them on the bottle.
Working used pump is fine but if someone with fast can lookup the part number please post it, I'm guessing they will be fairly cheap new if fitted to other models.
23 September 2014
Maryland
Correct me if I'm wrong but 14/15s pumps are universal. They look a little different but should pop right in.
immy21
9 November 2012
Edinburgh
Ah ok, since it looked different I didn't even attempt fitting it, I'l try and swap them over then report back :thumbs:
My front pump has gone, but never used the rear as deleted/removed the wiper, so just swapped the pipes around, works fine... not sure if you still have your rear wiper, but its an option?
If it doesn't fit drop me a message I have recently removed the factory bottle for something smaller so have both front and rear pumps going spare both in fully working order
