clutchs
C
cloudandy
clutch
its a OS Giken Super Single SD480.
I'll bring this up again :)
was originally thinking to get a Nismo clutch. But the Ogura 409 is cheaper and can take more power.
I find alot of different ones for the S15 though.
Nengun lists 7 different ones.
Which one should I be looking at?
Anyone have a part number?
What other parts do you recommend to change at the same time?
I'm going to get a new clutch line and operating cylinder.
Anything else?
i think i'll get the orc409 when i need one.
RHDjapan are slightly cheaper for it too when you consider you can pay with paypal, removing some of the "hidden fee's"
I only use nengun for the part numbers :p
I have sent enquires to Feast and perfect run. I'll look into RHD aswell.
Just wanted to know which of the 3 clutches with dampers I should get.
JP825
3 March 2006
Manchester & London
I just ordered a ORC 409 clutch for my RX7 too. Really wasnt sure if is going to be too hard to drive for road use, but my friend told me they are good and good price too.
I was tempted to go with their new ORC light series, but its a bit more expensive.
I think it might be a bit hard of you use the stock clutch cylinder.
I'm going to get a uprated Nismo cylinder aswell as a steel braided clutch hose while I'm at it :)
OK. I'll going to put in an order with perfectrun.
Is there anything else I need?
Ogura Racing clutch 409 series (Item Code: 409DS-02N5)
Nismo big operating cylinder (Item code: 30620-RS520)
Clutch line (apex?)
The clutch kit includes flywheel and release bearing.
Anything else?
yako the line can be gotten from hose solutions mate, theyre quite cheap too.
nice :)
I'll look around for the cheapest price regarding the hose.
So what about my clutch recepie?
Missing anything?
tripleJs15
I think the springs the are referring to are on the disc's, the S15 OEM and the Ogura ORC409D comes with a dampened flywheel.
tripleJs15
^ where did you order the clutch from ? I'm trying to get one right now.
Thanks
Thanks
perfectrun.com.au
There is a 2 week delivery time from Ogura and then another week for the package to get to Sweden usually.
This is what I ordered.
1. ORC Ogura Racing clutch 409 series (Item Code: 409DS-02N5): 83200Yen
2. Nismo big operating cylinder (Item Code:30620-RS520): 12500Yen
And then a clutch line from Apex-performance. master to slave cylinder.
ShawnS15
how the ORC clutch u all using. does it make a rattling noise when deccelerating (especially on 4th gear)
guys i am planning on changing clutch (switch away my ORC409, it damn noisy) does the cusco on fits? i mean for street and drift. power wise 350rwhp? does it hold?
tripleJs15
No mines doesn't make any noise decelling, however i get a little chatter in first only when pulling off and releasing the clutch pedal slowly. May be something else 4th gear, check the trans mount maybe
