Ultimate wheel fitting guide
8 December 2012
Surrey
9.5x18 all round
et30 all round
+20mm spacer front
+5mm spacer rear
effective et front +10
effective et rear +25
sits quite low with small arch roll all round, 225-40-18 stretched all round
-4.30 front camber
-1.45 rear camber... no rubing atall, used hard for skids :D
6 June 2010
Midlands
Can someone help here??
ive read that a 18x8.5 et32 is wat fits good on the front of the S15, so if I have 18x8.5 et37 and put a 5mm spacer on this will become et32 and fit ok??
thanks
Can anyone confirm this?
Yeah that's correct maths but I have et30 on mine and still needed a 3mm spacer to clear my coilovers so would probably get et25 if I bought a new set all depends on your set up tbh
6 June 2010
Midlands
Thanks, from what I've read COILOVER choice is a big factor aswell!! Well I'm bidding on some wheels in Japan so if I get them ill see if I have problems fitting
Would be your best bet as I was told the wheels I bought would fit 100% no problems and they didnt ha ha ha easy enough to sort out though
1 March 2010
Yamanashi, Japan
Im thinking about purchasing a set of Rays Gramlights 57F Pro Wheels in the following sizes:
F: 18x9 +33
R: 18x9 +30
Im lowered on coilovers, and my stock fenders (front and rear) are rolled...
Will i have issues with fitment?
I would also like to mention, i prefer not to change the camber settings in order to fit these wheels, so i can avoid getting an unnecessary alignment.
R
revhead
noob here. just got my first s15 but for months now i have been researching wheels specs and makes and offsets so i kind of know what im looking for and what goal i want. want i don't have much knowledge on is how different coil overs can have a different effect on how a wheel fits and how it effects your offset? the hub doesn't move further out or in when you fit a coil over, but im guessing the diameter of the spring has an effect on clearance issues with the inside edge of the wheel? how different are the sizes of the different coil over manufactures out there? im looking at running a 10" wide rear and a 9" front so my clearance is going to be tight.
im looking at work sp1 3p - front: 18x9 +22 A disk. rear 18x10 +30 O disk.
14 May 2011
northamptonshire
Hi mate,
Tbh with those offsets you'll be fine.
im running 10.5j et20 all round with a 15mm spacer upfront.
Shorty
2 May 2012
Aberdeenshire
www.daiko.co.uk
Boom!
New wheels fitted easily
Front-
17x9 et 25 however also a 5mm spacer so effectively 20.
Tyre- 215/45
Back-
17x10 et 20
Tyre- 225/45
On HSD Coilovers down pretty low, only needed to flatten the inner lip completely and that was it.
9 May 2013
Cornwall
Another fitment question for those of you who can help:
Front - 18" x 8.5J / ET15
Rear - 18" x 9.5J / ET18
Arch rolling necessary? Guessing strut clearance will be ok (HKS Coilovers...)
What size tires would I get to get them to clear? Camber adjustment?
1 March 2011
leicester
Arch roll would be needed. They would also stick out at the rear unless you were running a bit of camber. Nothing daft. Tyre wise I'd play it safe and go with 225 rears. Fronts should be okay with a roll.
9 May 2013
Cornwall
Cheers Ollie.
So 225/40 up front on the 8.5's, and the same for the rears? I was thinking 235/40? Or will they not have enough stretch to tuck in? I suppose it depends on the tyre type as well right?
1 March 2011
leicester
Ill try and take some pictures of mine this weekend pal as I'm running very similar sizes, rear wheels poke out quite a bit, I stretched tyres on the front but probably could of gotten away with it, I'm not running much camber on the rear though, will pull my settings out to give you an exact figure.
9 May 2013
Cornwall
That would be awesome, cheers.
1 March 2011
leicester
Hi mate, my wheels are xxr 527. (18s)
Front sizes are 8.75j +20 offset (tyres are 205/40/18 - Federal 595 evo's)
Rear sizes are 9.75j +20 offset (tyres are 225/40/18 - Toyo t1r's)
Camber settings -
Front - negative 1.59 degrees
Rear - negative 1.3 degrees
Fronts
Rears
Additional Info - i have HSD coilovers which the rears cover by a good 20mm, the fronts however are only around 10mm clear, no spacers required.
The maths (correct me if i'm wrong) -
My fronts
8.75j +20
From the hub the edge of the wheel is 8.75 x 25.4 = 222.25mm (width of the wheel in mm)
222.25 / 2 = 111.125mm (to the centre of the wheel)
111.125 - 20 = 91.125mm (the hub to the edge of the wheel)
Your Fronts
8.5j +15
8.5 x 25.4 = 215.9mm
215.9 / 2 = 107.95mm
107.95 - 15 = 92.95mm
My rears
9.75j +20
9.75 x 25.4 = 247.65mm
247.65 / 2 = 123.825mm
123.825 - 20 = 103.825mm
Your rears
9.5j +18
9.5 x 25.4 = 241.3mm
241.3 / 2 = 120.65mm
120.65 - 18 = 102.65
The result
Your fronts will stick out 1.825mm further than mine. (wouldn't be an issue with similar camber settings)
Your rears will stick out 1.2mm less than mine. (Better, but will still be outside the arch, unless your run at a guess 2-3 degrees neg camber on the rear.
I also have front and rear arch lips flattened back, no rubbing :)
Hope that all helps!!
9 May 2013
Cornwall
Ollie you are a legend mate, spot on. Thanks a ton :thumbs:
B
Burgies
Still going?
Hey guys is this still going on?
Im getting some XXR522's and cant decide on sizes, my options are:
18x8.5 +30 available in matte black & chromium black
18x9.5 +38 available in matte black & chromium black
18x9.5 +25 available in matte black, chromium black, and gold
17x8 +35 in chromium black, matte black, gold
17x9 +25 in chromium black, matte black, gold
17x9 +42 in chromium black, matte black, gold
I am thinking 18's but dont want too much of a hassle. I have stock suspension on low spring, propbably only about an inch of drop from stock height if that.
Any advice would be greatly appreciated!
Torchy
Hey
new to the silvia bug and i'm getting verry diffrent info from everywhere about fitment so i'm asking here
i want a staggered set , my posibilities :
18x8 et 35 or 45
18x9 et 22 or 50
i dont want to do fender rolling or ... Everything is stock but maybe a little lowering with different springs
can you help me with the et values ?
Sender
7 June 2008
Poland
It will work, if you don't have coilovers
Wysłane z mojego GT-I9300 przy użyciu Tapatalka
