DB's S15 Build Thread
13 July 2010
Brighton-UK
Hi Guys,
I’ve had my S15 for about a month so far and have been busy on the mods, manifold/down pipe fitted plus some bolt on parts (Blitz air filter/HKS SSQV3/Craft Square mirrors etc), waiting on the injectors to get the new turbo, Fuel Reg, HKS Fcon fitted and mapped.
I know the S15’s are sideways happy, and it may well be the Drift spec Coilovers but i’m finding the back end steps out just changing lanes when on boost? Ideas.. Having the suspension geometry check next week, hopefully it’s just the set up.
Wheels and engine internals are all planned for next year, will update as the build comes along.
Engine
Boost set at 0.9bar
Greddy FMIC hardpipe
HKS Oil Cooler
Greddy Filter relocation kit
Tomei Super Oil Block
HKS SSQV3
FWIN Ali Radiator
Blitz Sonic Power Induction Kit
Owen Development Manifold
Owen Development Turbo Downpipe
Owen Development GT2871r
Apexi Front Pipe
Apexi De-cat
Fujitsubo Exhaust
DIF Turbo oil and coolant lines
Billion/Samco/Greddy Hoses
Walbro 255l Fuel Pump
Cusco Strut Brace
GD CF Cooling Panel
Nismo 740cc Injectors
Tomei Type S Fuel Regulator
Greddy Fuel Pressure Reg adaptor
Circuit Sports billet fuel rail
Cusco oil catch can
Colour matched intake manifold and rocker cover (powder coat)
Suspension
Tein Type HE Drift Spec Coilovers
Tein Tie Rods and Ends
Energy Suspension Subframe Bushes
Energy Suspension Rear Arm Bushes
Driftworks Solid Diff Bushes
Interior
EPR CF Radio Surround
Yashio Factory Gear Knob
Yashio Factory Gaiter
Yashio Factory Spin Knob
Greddy gauges
Luxer1 Blue LED interior light
Alpine IVA-W520 (Double Din Touch Screen)
HKS Camp 2
Exterior
Advan AVS T6 17" Alloys
Carmake T&E - Vertex Lang Kit
BN Sports Bonnet
Yashio Factory LED rear lights
Craft Square TCA-N1 Mirrors
Moonface rear wiper delete
Electronics
HKS Fcon V Pro (ver 3.3)
HKS Fcon MAP and IAT sensors
HKS Camp 2 (with EGT, boost, water temp, oil temp, oil pressure sensors)
Apexi AVC-R
Clifford Avant Guard 5.5
YASHIO FACTORY Okachan Tenka Ignition Harness
Brakes
Front
Brembo (EVO) conversion
Anti-squeel shims
DBA4000 discs
Ferrodo DS2500 Pads
HEL brake lines
Rear
DBA4000 discs
Hawk HC+
HEL brake lines
Motul brake fluid
13 July 2010
Brighton-UK
reserved for updates
29 April 2009
Nice car dude! :) I assume it has the standard LSD and not a 2way as that would cause you to be skidding out easily!
13 July 2010
Brighton-UK
Cheers mate, I haven't checked yet, is there anyway of checking without having the Diff out? It's going in for the geometry check next week so I may well ask the garage to check the diff as well, good idea.
nice car mate, wearing my favourite kit of all - vertex lang :smitten:
i'd love to see this in the metal at some point, maybe we could organise a southern meet when the weather picks up in a few months time....
13 July 2010
Brighton-UK
Cheers guys,
Dean, yep sounds good mate, when the weathers not so shocking for sure we should organise a meet..
Looks very nice pal :) that Blitz Sonic Power Induction Kit looks good, never seen one of them before. What's your thoughts on it? any good...
13 July 2010
Brighton-UK
Cheers
A mate of mine has one on his EVO 8MR and it sounded awesome, you can adjust the funnel to change the sound of the intake, on mine however it doesn't have quite the same effect as the SSQV is so loud (love it though), only put it on a couple of days ago so need to play with the funnel, it's certainly nicer than the HKS one that was on it originally.
ok cheers pal, might take a look at one when I come to change my apexi filter :)
Jay
6 February 2010
Peterborough
nice motor mate, as for the stepping out issues, would it be the tyres on the rear? having good tyres makes a HELL of a difference on the '15. i found just changing to toyo's cured my car's sideways tendancies!
29 April 2009
I agree with Jay, tyres and alignment will make a huge difference! If its a 2way LSD you will probably hear it clunking when turning round corners mate and it would lock the rear up with the smallest amount of slip.
13 July 2010
Brighton-UK
Cheers guys
There's no clunking when turning so hopefully it's a stock diff, will try and get this confirmed when it's in the garage next week.
Tires wise I definitely have mickey mouse tires all round, rears are the ones that came with the car from Japan and the fronts needed to be changed as the vibration through the car was ridiculous, the garage changed the tires but fitted cheapos... (this did fix it though)
What Toyo's are you running, the T1-R's?
I think once the alignment is done next week I will need to invest in some new tires !!
i agree with the tyres statement mate, mine came with fairly worn potenzas which were trying to kill me, falken fk452's sorted it out a lot.
i'd love to do a meet soonish mate, but the car is in a lot of bits atm lol
13 July 2010
Brighton-UK
I know what you mean about trying to kill you, the car definitely has it in for me lol..
you doing some upgrades then?
polybushing, powder coating parts and rustproofing mate, better to do it before the rust gets hold of them ;)
13 July 2010
Brighton-UK
Update.
Fitted the Yashio Factory LED lights this morning, installation was plug and play which was good.
13 July 2010
Brighton-UK
DB's S15 Spec R Project
Hi Guys,
Started this in the Introduce Yourself section, but moved it here now, just a recap..
I’ve had my S15 for about a month so far and have been busy on the mods, manifold/down pipe fitted plus some bolt on parts (Blitz air filter/HKS SSQV3/Craft Square mirrors etc), waiting on the injectors to get the new turbo, Fuel Reg, HKS Fcon fitted and mapped, should be next month hopefully.
Brembo’s callipers bought for the front (waiting on DB-Power bracket), not sure what to do with the rear (Wilwood set up?)
Engine
Greddy Oil Cooler + Filter relocation kit
HKS SSQV3 (not recirc)
Fwin Ali Radiator (Billion rad cap)
Cusco Oil Catch can
DIF - Turbo oil and coolant lines
Circuit Sports Anodised Fuel Rail
Billion/Samco.Greddy Hoses
Cusco Strut Brace
GD CF Cooling Panel (Craig's GB)
Fujitsubo Exhaust
Suspension
Interior
Greddy gauges
Alpine Double Din Touchscreen
Exterior
Advan AVS T6 Alloys (Powder coated gunmetal)
Vertex Lang Kit
BN Sports Bonnet
Clear side repeaters
Electronics
HKS Camp 2 (Consult and Fcon harness)
Apexi AVC-R
Sweet car dude! Looks very clean,love the kit look forward to seeing your plans put into action and seeing your results
